South Central Region Board for the states of Texas, Oklahoma, and Louisana.
rear end issue
Old Oct 20, 2013 | 07:20 PM
txcop's Avatar
Car: 1984 Camaro RS
Engine: 350 CID 4 bolt (84 1-ton)
rear end issue
I was just given a 1984 Camaro, I was told they recently installed a Trans Am rear end with it... My question is why does the rear end stick out to the left in the wheel wells... it your behind the car looks like the rear end is 2 to 3 inches to the left????? is their a difference in the way the rear end mount between the two??????? any ideas would be greatly appreciated.....
Old Oct 21, 2013 | 08:12 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: rear end issue
Something is bent.
I would start by looking at the lateral link(AKA pan hard rod, AKA pan hard bar, AKA track bar,...). That is what maintains the lateral position of the differential. The factory part is not designed to be adjustable.
Your pan hard bar may be missing. If it is missing DO NOT drive the car.
Your pan hard bar may be bent.
You may have an aftermarket adjustable pan hard bar that is out of adjustment.
Your differential may have SERIOUS problems.
Your car may have been in a BAD wreck and be bent up in a way that is not immediately obvious.
You may have a 4th gen differential, but that would stick out on both sides.
Old Oct 21, 2013 | 08:17 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: rear end issue
Is your car lowered? Sometimes on cars that are lowered a lot with the stock panhard bar the rear end gets out of whack.
Old Oct 21, 2013 | 08:22 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: rear end issue
Another thought...
Do you have the same kind of wheels and tires on both sides?
Old Oct 21, 2013 | 01:53 PM
txcop's Avatar
Car: 1984 Camaro RS
Re: rear end issue
wow thanks for fast response guys.... to start vehicle is of stock ride height, appears to be factory pan hard rod not completely positive about yet.... I need so hoist time with the car.... damn thing my hoist decided to stop lifting. repair coming soon....uggg frame is ok had it at BS yesterday (buddy owns one) frame is A-OK he said didn't appear to be wrecked. as for the rest, I met the fella that was 2nd owner... without doubt that rear end is in-bread backyard hacked into car... I just have to get it into air I guess and see what the hell he didn't do properly... Now is their a site where I can get part numbers or proper dimensions on that pan hard rod???? I am guessing I need to break down and ****** a real shop manual for this crate... (wife took a shinning to it) I will have to get it ready for her to drive....
Old Oct 21, 2013 | 01:55 PM
txcop's Avatar
Car: 1984 Camaro RS
Re: rear end issue
yes ESC all 86 IROC wheels or so they look.... of course 86 iroc wheels with NO CENTER caps....LOL
Old Oct 21, 2013 | 01:56 PM
midias's Avatar
Re: rear end issue
Take a picture of the rear end that might help us.
Old Oct 21, 2013 | 02:58 PM
txcop's Avatar
Car: 1984 Camaro RS
Re: rear end issue
uploading to computer as I type...
Old Oct 21, 2013 | 03:21 PM
txcop's Avatar
Car: 1984 Camaro RS
Re: rear end issue
I hope I dl the photo properly
Attached Thumbnails rear end issue-1075.jpg   rear end issue-1076.jpg   rear end issue-1077.jpg
Old Oct 21, 2013 | 03:27 PM
txcop's Avatar
Car: 1984 Camaro RS
Re: rear end issue
yea wife took a shinning to it... now I have to polish this turd..LOL pretty sound car.... just have to undo the hillbilly hotrod mods...lmao!!!!! like the old foxbody's that was a travesty I have one that was easier to just prostreet it and yank the entire electrical system and re install with custom harness... course along with that I did a 948HP big block. she wants a cruiser so I am going to make it a Z clone that is what she likes... happy wife happy life...LOL
Old Oct 30, 2013 | 04:59 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: rear end issue
I've done the same thing with my 91. Yours looks as if your panhard bar isn't set right. jegs sells the adjustable for about 95$. Should allow you to remove that dogleg
Old Dec 5, 2013 | 04:48 AM
hillntx's Avatar
Car: 1985 Camaro SC F41
Engine: ZZ4
Axle/Gears: 3.42 Posi
Re: rear end issue
The other possibility is that your left rear wheel is actually for the front. The 16x8 rims are marked FRONT and REAR because they use two different offsets. If you put a FRONT wheel on the back of the car it will stick out more than a REAR specified wheel. If the previous owner damaged a wheel and wasn't careful about the replacement you may have three FRONT wheels and 1 REAR wheel.
Old Dec 5, 2013 | 05:25 PM
txcop's Avatar
Car: 1984 Camaro RS
Re: rear end issue
Huh....cool will check that out....doubt it though that would be to inexpensive of a fix.....LOL if it don't cost 500+ then it will not go wrong on this beast.....lololol
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
