South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Getting SFC's installed in Houston, TX?
Old Apr 26, 2001 | 09:07 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Does anyone know of a good suspension/chassis shop around Houston, TX? I want to get these things in perfectly. I have heard that a chassis shop would be the best because they will have the tools and equipment to make my chassis straight before they get put on. Thanks guys!
Old Apr 27, 2001 | 10:06 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I don't know of one, but if anyone does.. I would really like to know also.
Third Gen Project
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
"Stock?! Theres nothing "stock" about a stock car."
Old Apr 27, 2001 | 06:07 PM
Scott_92RS's Avatar
Car: 1992 RS
Does this mean that no one has subframe connectors in Houston? Come on guys, help a fellow thirdgenner out! Thanks
Old Apr 27, 2001 | 10:24 PM
Ragin'87's Avatar
if you can find a good body shop, they should be able to weld them on good and straight.. you are getting weld-in right? Personally I wouldn't count on anything that only bolts on for major chassis stabilization in any long term application. Strut-tower brace, but if I could say I would NEVER have to pull an engine out of a car, I'd weld that in too.
in any case, a lot of good body shops have chassis-liners, or their bodyworkers know enough to get things straight. you would be looking at quite a lot of money to get your chassis straightened and SFC's installed, I would just go w/ the SFC install, but get someone that can do good structural welding to do it.
Anthony
P.S Out here in Katy, i know David at Kiwi Auto Body has welded SFC's for a guys Mustang, they don't have a chassis-liner anymore though. You might try a Mike's Muffler, the guy at the one next to Texan Ford is an excellent welder.
Old Apr 30, 2001 | 04:43 PM
87IROC350's Avatar
Engine: 5.7
I bought some SSM connectors last year and haven't got around to installing them. I just called Mike's muffler between Mason & Fry on I-10 and they said they charge $75 to install and possibly as low as $50 depending on the difficulty. I've had really good luck with the guys at Mike's muffler when I have had other work done on my car. I'll probably take it by some time next week and have them installed.
87 Iroc 5.7, AFR190, SLP Cam(218/224), SLP 1 5/8 headers & cat back, Random CAT, SLP Runners, 48mm TB, custom chip(by me), Vigilante & Probuilt trans.
Lmancha96
Oct 22, 2020 12:40 PM
xbmx89
Oct 31, 2015 10:59 AM
akanitro
Sep 20, 2015 12:50 PM
hayesaw0210
Aug 23, 2015 11:15 PM
AkDrifted
Aug 17, 2015 07:45 PM
