South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Tires
Old Jan 22, 2002 | 07:49 PM
89Formula5.0's Avatar
Tires
What are the best street tires out there for this size: 245/50/16?
Should i stick with this setup or goto 255/45/16.......
Give me the best tire's brand name, and the name of the tire, and cost.....
Also include if these tires are on your car or have used them before and seen significant results...... or any improvements.....
Currently i have BFGoodrich Comp T/A ZR's 245/50/16.
Old Jan 24, 2002 | 11:07 AM
89ROC's Avatar
I got Yokohama AVS Intermediate 245-50ZR-16. only $86ea from tirerack.com
These tires get excellent traction for street tires, probably the best I've ever had.
Old Jan 24, 2002 | 12:56 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
IF you want teh bet combiination of wet/dry traction and speed rating, the best is teh BFGoodrich G-Force t/A KDW, available from tirerackfor 128 a tire. It is YR rated(186MPH) and has a VERY aggressivve tread pattern, and is available in the stock 245/50R16 size. 255 will not do to much for you, due to the contact patch remaining about the same.
Old Jan 25, 2002 | 01:36 PM
I have heard of the KDW's.... but they are expensive!
Has anybody in here heard of the Kumho's?
The Yokohomas seem to be inexpensive and 89ROC says they provide excellent traction for street use.....
How do the Goodyear GSC's and the Nitto's: NT555 compare to any of these?
The Nittos are priced the same as the BFGoodrich Comp T/A ZR's
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
