Dart heads and other parts FS
Subscribe
Jan 19, 2009 | 12:59 PM
Alright, i built this motor and i had about 150 miles on it before the oil pressure started to act up, EVERYTHING was new...except the used roller cam i got a deal on..so it screwed up the cam bearings, i decided to go another route so it is all up for sale...
Dart Pro 1 230 CC heads, aluminum, 64cc chamber, ported, 2.08/1.60 valves, big springs, 7/16 rocker studs...950$ nego
Crower 1.5/1.6 split ratio roller rockers, 7/16 poly locks...100$
350 block, .030 over bore, 1 piece rear seal, 87+, 4 bolt main, centers ARP bolts, outer studded, line bores. Will be honed before sale is complete unless requested otherwise. Minor clyinder rust from head removal sitting in garage.
Clearanced for stroker crank, 6 inch rods were used. 300$
383 rotating assemblie, forged Kieth Black pistons, .030. For 6 inch rod, 4 valve relief flat top, 11 to 1 compression with 64cc chamber, 6 inch Scat I beam, Capscrew rids Forged, goo for over 600 HP(advertised), Scat 9000 Stroker crank, 1 piece rear seal, 3.75 stroke.
All balanced by 105 machine shop, 800$ nego...
OR, buy rotating assy and block for 1000$
OR, take it all for 2000$, i have 4000$+ plus in all parts and machine work.
zones89rs@yahoo.com
Z
Reply 0
Subscribe
