South Central Classifieds for the South Central Region
Drivetrain
Old Apr 17, 2009 | 06:22 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Drivetrain
If all goes well I will be doing my engine/trans swap in about a month. Want to see if I could sell my complete engine and trans with comp.and harness and all emissions and complete exhaust or would it be better to part it out. If someone needs a complete setup here is the description:
5.0 TPI 87,000 miles
700R4 Trans rebuilt at 80,000 miles
Stock driveshaft with new u-joints and balanced
1985 OEM Computor and harness with Hyper-Tech chip
Mass air flow sensor,air filter housing and all related
All emissions,exhaust manifolds,y-pipe,Magaflow cat-back,cat
Engine has new IAC,Summit throttle body,replaced rear main seal and pan gasket,replaced intake manifold gaskets,new cap and rotor,plugs,wires.
New stock radiator,new water pump(Stewart)
All brackets,a/c compressor,new fan belts
In other words ready to install and run.
Let me know and/or give me your opinions.
Old Jul 15, 2009 | 11:52 AM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Re: Drivetrain
I was wondering if you might still have this setup available. I will be converting my T-5 to a auto pretty soon and will be needing some parts. Also interested in your TPI setup if you have it.
- Rex
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
usafirebird
Oct 1, 2015 01:57 PM
Chevykid810
Sep 28, 2015 12:57 PM
usafirebird
Exterior Parts for Sale
Sep 21, 2015 01:23 PM
2slowfox
Sep 18, 2015 01:49 PM
