South Central Classifieds for the South Central Region
LT1, Eagle, Hypertech and more parts for sale
Old Dec 9, 2009 | 01:17 PM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
Many parts for sale, click links for pics. Buyers to pay actual shipping costs.
Eagle/TRW Balanced Rotating assembly
355 Crank p/n 103503480 $50
5.7 Forged I beam p/n 5700BPLW with TRW pistons pressed on. Piston p/n L2256F30 $350
Pistons do not have rings. TRW calls for p/n E-251K030
Short block was on an engine stand and during transport, a sharp low speed turn sent the engine over the side(engine stand anchored to trailer). The crank snout ground on the pavement a bit as we pulled over, its not too bad though. You can see it in the pics. Pistons and rods were inside the block and sustained no damage.
http://img262.imageshack.us/gal.php?g=eaglecrank1.jpg
Granatelli MAF Sensor p/n 350111 for LT1. Housing is a little worse for wear, but operates properly. $225
http://img686.imageshack.us/img686/4554/mafsensor.jpg
Chevy 350 Connecting Rods (supposibly pink rods, but they aren’t powdercoated pink??) $35
http://img515.imageshack.us/i/gmpinkrods.jpg/
Summit Roller Timing Chain p/n sum-g6601 $20
http://img515.imageshack.us/i/summittimingchain.jpg/
GM 10 bolt 3.08:1 Ring and pinion. Came out of a 96 full size pick up with less than 30k miles. Been sitting in my closet for years in a Richmond gears box which replaced the 3.08. $75
http://img686.imageshack.us/i/3081ringandpinion.jpg/
LT1 Balancer/underdrive pulley assembly for corvette accessory.ASP-945800 $100
http://img704.imageshack.us/i/lt1underdrivepulley.jpg/
Campbell Hausfeld 30 gallon Air Compressor 6.25hp, 120 volt, 7.2scfm@40psi, 5.7scfm @ 90psi. It’s in good working order, sticker/decals are partially torn off. just add a hose and you are ready to go. $200, pick up only.
http://img707.imageshack.us/gal.php?...ompressor1.jpg
Pontiac 455 Block. 485428 casting number on the rear. $100
http://img710.imageshack.us/gal.php?g=455block1.jpg
Craftsman Coolant Pressure Tester Model 46342. I couldn’t get this thing to work lol. Like new. $45
http://img171.imageshack.us/gal.php?...antpressur.jpg
Power Programmer Plus p/n 360202 with new 160 degree vortec engine thermostat. This is an early model of the power programmer 3 for 96-97 Chevy Full Size trucks. It does just about everything a PP3 does. Allows for Engine powertuning if you have 160 thermostat installed, tire size calibration, rear axle ratio calibration, top speed limiter, firmer transmission shifts. It is just an earlier version I bought back in 1996 for my 96’ full size. Sold the truck a decade ago, after I unprogrammed it. Chip has been sitting in my closet since then. $100
http://img704.imageshack.us/gal.php?g=18558896.jpg
I live in Spring, TX.
NBrehm
Aug 25, 2015 11:49 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
