South East Region Regional Board for South East Members.
V.A.T.S the Hell
Old Apr 3, 2007 | 10:04 PM
speedracer0626's Avatar
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
V.A.T.S the Hell
89 Firebird 2.8 Converted 305 Lost The Keys. How To change the ignition assy. Do I have to replace the old with a new one of the same value. If so how do i figure out what value I had orignally. My Dealer told me i would have to have the car towed to the shop and everything replaced for about $500. B.S! I can Get one from Classic ind. $65. Does The ecm store a certain value, Or can i just dreop one in and go
Old Apr 4, 2007 | 10:26 AM
Re: V.A.T.S the Hell
The Dealer Said That his computer only goes back 10 years. So I guess i just drop one in and hope for the best. I could Bypass it but like to have right.
Old Apr 4, 2007 | 10:37 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
You could have a locksmith make a key just for the cut and somewhere on here there is a list of resistances used, get1 resistor of each value and temp put it into the VATS wires coming out the bottom of the column until you find the right value that lets you start. then whatever value # the resistor that worked have a key made with that value. Probably take a while and whatever it would cost to have the key made and the resistors, but I would guess a lot less than 500.
You will more than likely have to prove to a bunch of people you actually are the owner of the car.
Old Apr 7, 2007 | 01:32 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
IF you can find someone with a car they are parting out you can get the module, keyset and the switch and pop it into your car. i had 2 parts cars not long ago and i had all of this but i let the modules go with the cars but saved the keys and coulms. wished id saved the mods and i woulda sent ya the stuff for dirt to help ya out. best bet is what i sugguested. the mod is behind the HVAC controls but if the car is being pulled apart it should be easier to access.
Old Apr 7, 2007 | 01:39 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
here ya go, fella is parting out a car, see if he has the items i mentioned.
https://www.thirdgen.org/forums/engi...ula-350-a.html
Old Apr 7, 2007 | 01:59 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Can't you disable the VATS in the ecm if you know someone that can tune chips?
I dont know how it works with stock ecms though.
Old Apr 8, 2007 | 02:05 AM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
me personally i wouldnt want mine disabled. a friend had his car ripped and his vats was off, after he got his car back he had it turned on. iv heard of more than 1 story where vats has saved someone a stolen car.
but yes, you can have the vats turned off but you would need a zif socket and a chip to copy your program to and the tuner just flips a box in the programming and the rest stays the same no sweat.
moates.net (i think thats right) has all he chip gear ya need to do this.
Old Apr 8, 2007 | 05:20 PM
Yeah I would perfer it to work. So i took it apart and will be going to radio shack to get all 15 and go from there. Thaks bilms and quick chicken
Old Apr 21, 2007 | 07:01 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Probably not what you want to do here, but I ran an override starter button to the starter wire past the VATS system and concealed the button so it's not obvious. As it turns out, since the VATS isn't working properly, half the time it wont start with the key and it has the correct resistance value. That's when I use the button. I consider it an anti-theft even if my keys get stolen. Anyway, my wiring system had some issues anyway from previous hack jobs that I didn't mind running this properly while I was in there fixing some of the previous hacks. Just an idea.
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
