Which tires to get?
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Which tires to get?
I need tires for the Maro and I want some good ones but don't know what to buy. I was looking at the eagle I or II's but are they any good? I want some high performance "Z" rated tires. Any ideas would be helpful. Thanks.
Car: 1988 Trans Am GTA
I have Yokohama yk420s. They are v rated, but the other day I drove (aggresively) up to summenrhaven during/after a storm, and never lost traction. If that means anything to you
These are H-rated passenger tires.
They are not touring tires and absolutely not performance tires.
So I should clarify a little more. I want a tire for high performance that has good traction in the rain. How about the yokohama AVS ES100? Anyone using these? They seem to be low profile type tires. I don't want low profile tho.
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
I'm running them, 275/45 17. I think they are noisier than the Firehawk SZ50EP's I used to run, but Firestone doesn't make the SZ50s any more.
Side to side grip is good to excellent. Front to rear isn't as good as the Firehawks, but these do well on wet roads.
They've been on for a year now and there is lilttle tread wear, unlike the Firehawks.
The tread pattern is fairly agressive, which I liked and TireRack had a decent deal on them.
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
My 92 Z28 put two years in Prescott and the Northern AZ area on Potenza 730s recently and had no problem with them. Also had them on my 87 IROC, but one blew out, I guess from sidwall rot. Now the 730s are not produced anymore, so I bought a set of yokohama AVS ES100s. I like them a lot, both in hot weather and rain. The yokohama AVS ES100 is an excellent tire for less then $100.
Car: Sexy
Engine: Stock
Transmission: Slipping
Firehawks are touched by (diety of your choice). I have Firehawks on the back and Potenzas on the front, I can almost launch in the rain.
Engine: 5.7
Originally posted by CaptPicardsZ28
Is it a low profile tire? It seems to look that way in the pic on tireracks website...
Here are the choices I have so far that interest me based on the description given at tireracks website:
BF Goodrich Radial T/A, Firehawk Indy 500 with UNI-T, Yokohama Avid S/T, or es100's and Goodyear Eagle #1 Nascar....not sure which ones I like better. Ratings were highest for Firehawks then Yokohamas, Goodyear and lastly BF Goodrich. They all had an S or T rating and I believe the es100's have a higher rating either V or W...
Car: Sexy
Engine: Stock
How often do you plan on keeping a *sustained* speed over 112 mph (S rating)? Sustained doesn't mean trips down the 1/4 mile either. Z ratings are for over 150 mph sustained, which if you're doing that... tell me in advance so I'm not on the highway at the time.
I've had BF Goodrichs on the back, and the hooked like crap. The Yokohamas were a little bit better, their benefit is rain traction and handling. Firehawks were brought down the mountain along with the 10 Commandments.
I like the firehawks and the yokohamas the best...as for size, I am sticking with 15's all around. As far as ratings go, why bother with them if noone sustains those kinds of speeds? I think there is more to ratings then that. Our cars came with Z rated tires if I'm not mistaken. Why?
Car: Sexy
Engine: Stock
The origin of the ratings in the first place was for use in places like Germany where cars actually do those speeds. The original definition of the ratings was in km/h for that reason.
I suspect they (meaning Irocs) came from the factory that way because our cars are capable of those speeds and it'd be a hell of a lawsuit waiting to happen if they didn't. RSes and V6s didn't come with Z rated tires. AFAIK
Which is of concern to me because my tires tend to crack with age because they don't get much use. I'm not sure tho if softer tires or harder tires would prevent or slow that process.
Car: Sexy
Engine: Stock
All tires crack with age, softer tires tend to do it faster which is why people who run slicks have tire covers over the tires. Just get some covers for the tires for when it's parked.
It does...here's what someone said about those tires:
Also, they say stuff about treadwear 420, traction AA, temperature A, do these things indicate sub par tires as well?
And as far as my experience with them driving dangerously in the rain, I guess you don't have to believe me if you don't want to
Oh well
I hope that when you get new tires, you don't get ****** like I apparently did!
Sorry, I didn't mean to lead you wrong, I was just under the Impression that when my tires say P245/50 R16 96V It means they are 16 inch rimmed, 96 load rated, V speed rated radial passenger tires. And V rated meaning, according to the wierd yokohama scale, that they are good to sustained speeds of 149 mph. I didn't know all those numbers and letters mean H rated. So how do I read the information on the sidewall of my tires correctly?
Oh well
Oh well
I stand corrected blasto....your reading of your tires was correct. I checked the tirerack website again. You have V rated tires with a load rating of 96 which means one tire will handle 1565 pounds.
Engine: 5.7
Car: Sexy
Engine: Stock
I am not understanding your response...I think your tires are R rated which is what the R16 is.
I'm guessing he's shopping for 15 inch tires because he has 15 inch rims.. I could be totally off, though.
I your reading of your tires was correct. I checked the tirerack website again. You have V rated tires with a load rating of 96 which means one tire will handle 1565 pounds.
Sorry for any confusion. Hope you tell us what you fianlly got Captain
Originally posted by Synapsis
It's for Radial.
It's for Radial.
Why shop for high performance road tires in the 15-inch size? Having had both 15 and 16-inchers on my IROC, I noticed tremendously better handling with the larger wheels. Stock 91-92 16-inch wheels are pretty cheap and 50-series tires will keep the chassis at the same ride height as 15's.
Car: Sexy
Engine: Stock
Better handling with 16" wheels is because there's less sidewall to flex, which also results in a little harsher ride. Having more sidewall is better for traction when launching in a straight line for weight transfer and planting the tires to the ground.
OK, I ordered the tires today and they will be here next Tuesday. I went down to look at them before buying even tho I knew what I wanted and it seems that I will have to have white lettering on the outside because the blackwall side looks like sheit in my opinion. With a front end alignment the cost comes to 461.00 installed. I went with the Firestone Firehawk Indy 500's.
Pics next week...
Pics next week... Last edited by CaptPicardsZ28; Jul 27, 2005 at 02:19 PM.
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Thats funny!!!
Woot! I was about to throw my tires through the window of discount tire like the old lady in that commercial.
Engine: 5.7
OK, I ordered the tires today and they will be here next Tuesday. I went down to look at them before buying even tho I knew what I wanted and it seems that I will have to have white lettering on the outside because the blackwall side looks like sheit in my opinion. With a front end alignment the cost comes to 461.00 installed. I went with the Firestone Firehawk Indy 500's. :D Pics next week...
That's what the Hawaii installer told me when I had the tires shipped to them -- even though the store is a recommended TireRack installer -- the store said that I would have received those benefits if I had bought the tires from the Hawaii store [and of course paid a much higher price per tire].
If you ordered the tires from Tirerack, did the local installation facility deny you lifetime balance, rotation, etc, even though they installed and balanced the tires?
Car: 2007 Infiniti G35 SEDAN
Engine: 306HP 3.5L V6
Transmission: Auto Pilot Baby!!!!
Axle/Gears: Don't care!
IMO I think the "someone" that told you about them doesn't know their *** from a hole in the ground.
Originally posted by UmmaGumma
I tell you what dude... I drove on those Yoko YK420's for 2 years with my Camaro. Whenever they blew out or wore down they were always replaced with a freshie. They had better traction that most others I've tried. They're not hard. The give an awesome ride and really do have good traction in rain. Just ask 90_WS6_Formula. He bought my set from me when I parted the car out. They're priced pretty well too.
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
not sure if u have 16's or 17's. if u have 17's, id go for a set of nittos. if 16's... i have no clue. im in the same boat with those irocs i got. no clue, besides thsoe new ET streets, for a good tire thats 16"
Originally posted by AZ406TPI
well **** then.. haha. i know for sure there are some nice size ET streets for 15's.
then get the turd a set!
then what do u want?!?! haha
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
