South West Region South West regional discussion board.
Firebird Friday?
Old Feb 8, 2006 | 11:05 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Firebird Friday?
Well, I found out I can't pass emissions so I have thirty days to correct it or no more streets....
I am definately going to Firebird Friday night....It would be cool to see some people from the board out there....
Anyways I am going...Would love to see some people there....
And on a side note....If anyone has a Helmet I can borrow (not that I will get under 14) But damn this car seems alot faster than my other 87 and it pulled 14.98.... Firebird has a new helmet rating so if you got one I can use it has to be
10. Helmets: Drivers of all vehicles running 13.99 or quicker, and ALL convertibles regardless of E.T., must wear an SFI-approved helmet with a Snell rating of 95 or newer. Passengers in convertibles running 14.00 and slower must also wear an approved helmet. (Note: DOT-only helmets are not permitted. SFI-approved helmets are not permitted if the Snell label inside the helmet is missing or illegible. In other words, a Snell-rating on the outside of the helmet is not good enough.)
Old Feb 9, 2006 | 07:07 PM
Car: 85 87 87 91 92
What? Nobody?
Old Feb 9, 2006 | 11:52 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Can't this friday...or next But hopefully after that I'll be running fairly consistently.
Old Feb 10, 2006 | 12:45 AM
Car: 85 87 87 91 92
well after the 8th of next month if I can't get thru emissions i wont be able to drive on the streets. So I have got to get my runs in now.
Old Feb 11, 2006 | 02:32 PM
Car: 85 87 87 91 92
Ok so Firebird didn't go over that Great....
1) Traction was terrible (but expected that)
2) Tranny could not handle motor. I had to completely let of the gas, push in the clutch, shift then punch the gas....And by no means be fast about doing it....
3) I had to start off the line like an old lady that doesn't have enough strength to push on the gas pedal.....then slowly give it gas and hope I don't break the loose the tires.
My worst time 17.43
best time 15.07
Anyone have a tranny that can handle power...and high torque 6000 RPM shifts without having to grind in to the next gear?
Old Feb 11, 2006 | 03:05 PM
toms84ss's Avatar
I got two used T-5's I'll trade you.
Old Feb 11, 2006 | 10:29 PM
Car: 85 87 87 91 92
I don't think a t-5 is going to be strong enough....
AussiePr0nCar
Mar 6, 2020 04:04 PM
TheJoeY88
Mid-Atlantic Region
Aug 8, 2017 08:15 AM
akanitro
South Central Region
Sep 20, 2015 12:50 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
Camarothatcould
Aug 20, 2015 08:49 AM
