South West Region South West regional discussion board.
overheating
Old May 31, 2006 | 12:00 PM
MY84CAMARO06's Avatar
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
Axle/Gears: DONT KNOW MUCH ABOUT CAMAROS
overheating
the radiator was just replaced 4 months before.it over heats.i turned the heater and it quit stemaing.i drove it for 5 miles and it was ok.the fan does not come on.is it the thermostat sensor. or could the fam not working actually make it over heat that bad..
thanks devan
Old May 31, 2006 | 12:23 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Well, to start off, checking exactly what you wrote might get you further. Proper English will go a long way.....
First thing that you'll want to check is that you have enough coolant in the system. make sure your not running just water or something foolish like that. Next, check to make sure you have a thermostat on the motor and check to make sure that it isn't frozen shut. Next I would test the fan. Get yourself a repair manual and look for how to test it. Also, does the fan come on when you turn on the A/C? Is the fan plugged in? Is the fan relay switch plugged in?
Other than those suggestions there, I would also check with the cooling board. This will give you a base to start off with and once you have that info, we can help you more. Good luck.
Old Jun 1, 2006 | 08:02 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
replace the t-stat and gasket,its like 20 bucks...takes 30 minutes.use a little rtv on both sides of the gasket. dont use a bunch.dont put the t-stat in upside down either.if the fans arent working.thats most likely why its overheating 99% sure...oh.you could have a something blocking the radiator...make sure their isnt a plastic bag or something on it...after u replace the t-stat.fill w/ coolant,start the car and let it run till all the air gets out."you can tell when the airs gone because the t-stat will open,and the upper hose will get hot and youll see the coolant level drop".also replaced the radiator cap.
Old Jun 2, 2006 | 01:33 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
i kinda have the same problem, my fan never turns on so i just kick the it over to warm and put it on max to get my fan on, my t-stat is brand new and i just flushed the whole system out real good.. still dont turn on..
Old Jun 3, 2006 | 05:33 PM
Transmission: t-5
check the fans powers and grounds.check fuses also.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
