South West Region South West regional discussion board.
Fan Problems Help???
Old Jun 5, 2006 | 12:53 AM
Abanda's Avatar
OK on my most recent drive to avondale my car started to overheat. When i say overheat i mean in the red. Well i pull over open the hood with the car running and noticed that the driver side fan was not even on!! Now my question, can i just replace the fan motors (if that is the problem) or would i have to replace the whole assembly. I have checked all wires and they are in good condition since the motor is pretty much pull out bolt on according to Haynes, would that solve it??
Old Jun 5, 2006 | 01:09 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
The fan motor can be changed independently of the other components. However, before buying a replacement, hot wire it to 12-v to determine if it's actually bad, as there are other parts in the cooling system which can prevent the fan from turning on. FYI carrying an extra fan motor is a good idea when going on the road, as are spares for relays, the heater directional valve and a short piece of metal or plastic tubing to connect the heater core inlet/outlet when it blows out on a hot day.
Old Jun 5, 2006 | 01:12 AM
Abanda's Avatar
I am a newbie when it comes to the wiring part of the car. HOw would i wire it to a 12v source and what wires would i look for to do so.
Old Jun 5, 2006 | 01:19 AM
Duck's Avatar
Engine: 5.7
Recommend you ask a buddy for hands-on help. No sense in starting a fire or damaging components if this level of troubleshooting isn't within your level of experience. Good idea is to get a Haynes book and read through the instructions which will basically have the mechanic take power from the battery and connect it to the fan motor electrical connector.
Old Jun 6, 2006 | 07:50 PM
90_WS6_Formula's Avatar
Car: 91 Z28
go to a junk yard and cut off the wiring pigtail for an electric fan
plug into fan and touch one side to the positive (+) and one side to the negative (-)
GM fans are bipolar so you won't burn anything up running them backwards if you get the polarity switched
if your fan runs like raped ape then it's fine... start looking at the relays suspiciously
I hope this helps
Old Jun 7, 2006 | 11:05 PM
Abanda's Avatar
ok i fixed the fan. It was on of the wires that power wires that ran to the primary. It was broken just on the outside of the female connector. The thing is now it run hotter faster. I noticed that my fans spin opposte each other. the primary spins clockwise while the secondary runs counter clockwise. is the this the right way? also i am thinking of replacing the water pump once i get the money as that is the last thing that i havent replaced yet.
Old Jun 8, 2006 | 04:05 AM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
i might be drunk, or i might be a genius.. but i think the should spin the same way,, i only have a RS and i only have a single fan but you can look at the blades and tell which way the air is going to move if the fan is spinning, if its the wrong way.. someone did say bipolar so im thinkin... wrong polarity.. then again its 2am and i am drunk
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
