South West Region South West regional discussion board.
PARTING OUT THE 89
Old Jun 30, 2006 | 09:59 AM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
PARTING OUT THE 89
If anyone need anything it is a complete car it is all there, for a list of fun stuff check out the sig. if you have any questions call Tyler 520-405-7703 or formula305TBI@msn.com
I will be tacking the motor apart if you want any heads or intakes I have a few carbs 600 and 750cfm
Last edited by 2kickassbirds; Jun 30, 2006 at 10:03 AM. Reason: Automerged Doublepost
Old Jun 30, 2006 | 10:09 AM
Engine: 5.8
sig
Old Jun 30, 2006 | 10:16 AM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
How much for teh BBK pulleys? Thanks!
Old Jun 30, 2006 | 01:33 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
do you have a dual fan setup? if so how much. What kind of heads do you have. is the intake oem?
Martin
Old Jun 30, 2006 | 01:57 PM
Engine: 5.8
I have a single fan. the heads are l31 vortec ported with 2.02 and 1.6 valves about 1500 miles on them the intake is a performer rpm for vortec heads but I do have a dual plane intake as well
Old Jun 30, 2006 | 01:58 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
how much for the intake manifold, the shift kit, and the hedmen headers?
And also, I have been interested in getting gears for some time, what kind do u have? 3.42s or 3.73s? How much would you sell for the complete set?
Old Jun 30, 2006 | 02:14 PM
Engine: 5.8
i have a set of formula rims 16x8 with center caps $80.00 150 for the rpm intake, the shift kit is in the trany and 40 for the headers no y pip. i have a set of 3.42 and 3.73 2 series 40.00 each
Old Jun 30, 2006 | 03:02 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
the gears themselves for 40? Or for the entire set?
And are those gears 2 series? Or 3 series?
EDIT: how big are the headers
Old Jun 30, 2006 | 03:32 PM
Engine: 5.8
3.73 are 2 series for 40.00
3.42 are 2 series for 40.00
1 5/8 shortie
Old Jun 30, 2006 | 03:54 PM
Engine: 5.8
Hear is a small list
L31 heads ported 2.02 1.06 valves 2000miles 700.00
Performer rpm vortec intake 150.00
Holley 600 VS carb 75.00
Holley 750 VS carb 100.00
Th700r4 with shift kit about 11000 miles 500.00
Serpentine belt system 50.00
1.6 Roller Rockers 100.00
BBK Underdrive Pulleys 40.00
3.73 are 2 series 40.00
3.42 are 2 series 40.00
Lakewood lower control arms 30.00
Hedman Headers 40.00
Formula 16x8 rims 80.00
wonder bar 30.00
Duel plan intake vortev never used 50.00
Chevy 327short block 2000 miles new everything bored 30 over9.8 comp with 64 cc heads ran grate 400.00
Any random part make me an offer
Old Jun 30, 2006 | 05:37 PM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
ok i have a 3.08 gears right now. and im not sure if my rear end will accept the 3.73 gears and if you know any info if they do fit ill take them.
martin
Old Jun 30, 2006 | 05:49 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Martin, 3.08 is a 2-series rear. So you should be fine running what he is selling.
I want the wonderbar and consider me 2nd in line for the BBK pulleys. Are they for the serpentine or V-belt setup, or does it not matter?
Old Jun 30, 2006 | 07:14 PM
toms84ss's Avatar
Sent you a PM.
Old Jun 30, 2006 | 09:48 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I know a guy who might be interested in the 700R4, I'll let you know when I do.
Old Jul 2, 2006 | 07:08 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
What color is the interior, and what heads are on the 327?
Old Jul 3, 2006 | 12:25 PM
Engine: 5.8
It is no longer being sold as a short block but as a complete turn key motor carb to the pan
Hear are some specks chevy 327
KB Hypereutectic piston 9.8 Comp Ratio
Ported L31 vortec heads 2.02 1.60 valves
Performer RPM airgap Intake
Comp Xtreme Energy cam
Cloyes True Double Roller Timing Chain
1.6 Roller Rockers
ARP Main Studs
Holley 600CV
New distributor
And everything you need form air cleaner mounts all the brackets belts pulley stator, as it came out of the car I have it all so if you are looking for 400+HP with good street manners not even 2500 miles on it, ran perfect. 2000.00
Old Jul 5, 2006 | 06:29 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
How about the A/C controls and the wiring in the console? How's the dash pad? Do you have the plastic valve under the hood for the heater? The gas tank fuel level sender assembly? Trunk curtain (in black)?
How's that for a random list of non-performance parts?
Old Jul 6, 2006 | 03:18 AM
Engine: 5.8
no ac controls
come cut out any wiring 10.00
dash pad is only 1 year old 35.00
as far as the gas tank fuel level sender assembly with pump 50.00
no curtain
Old Jul 6, 2006 | 10:02 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Aww man. I mostly needed the A/C controls. Oh well.
Old Jul 6, 2006 | 01:48 PM
azmrz's Avatar
Car: 91 z28 5.7
If the dash pad is still available, I am interested in picking it up.
Old Jul 6, 2006 | 07:49 PM
Engine: 5.8
still have it
Old Jul 7, 2006 | 12:32 PM
azmrz's Avatar
Car: 91 z28 5.7
PM sent regarding dash pad.
Old Jul 14, 2006 | 05:46 PM
Engine: 5.8
come on it has a straight body and good interior and it is black
Old Jul 23, 2006 | 02:40 AM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Still parting this car?
How's the condition of the center console, radio pod, A-pillar covers and the various plastic pieces around the dash?
Old Jul 23, 2006 | 04:57 AM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
complete motor or for parts only
Old Jul 23, 2006 | 08:08 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
is your shifter plate and auto shift **** in good shape? how much? ml258@yahoo.com
Old Jul 23, 2006 | 11:14 AM
Engine: 5.8
i have the A-pillars 25 for the pair
the moter is complete runing from the carb to the pan it is a turn key motor
No console stuff
Old Jul 23, 2006 | 01:44 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
price and mileage on motor?
Old Jul 23, 2006 | 08:21 PM
Engine: 5.8
1.6 Roller Rockers
ARP Main Studs
Holley 600CV
New distributor
And everything you need form air cleaner mounts all the brackets belts pulley stator, as it came out of the car I have it all so if you are looking for 400+HP with good street manners not even 2500 miles on it, ran perfect. 2000.00 obo
Old Jul 24, 2006 | 01:34 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Old Jul 24, 2006 | 01:43 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
well if ya change yer mind im interested in this
Old Jul 25, 2006 | 12:20 AM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
does it have the vat key setup? if so can you send me the whole thing, key, lock cylinder and the box which is located on the steering column. let me know how much thanks.
Old Jul 27, 2006 | 04:35 PM
Engine: 5.8
it neve took a key to start my car so no i doint have that
Old Sep 2, 2006 | 08:51 PM
'Shifter's Avatar
Car: 87 Z-28
Still have the diff? Drum or disc? 10 bolt or 9?
Old Sep 3, 2006 | 02:43 PM
Engine: 5.8
have a 10 bolt drum 3.73 open 50.00
Old Sep 3, 2006 | 07:01 PM
'Shifter's Avatar
Car: 87 Z-28
What part of Tucson are you in....
Old Sep 3, 2006 | 11:12 PM
Engine: 5.8
east side
Old Sep 4, 2006 | 04:41 PM
'Shifter's Avatar
Car: 87 Z-28
east side
Excellent...I work at Merles on 22nd between Pantano and Sarnoff...are you
close to there?
Old Sep 4, 2006 | 05:09 PM
Engine: 5.8
close to there?
yes about 15 minutes form there
Old Sep 5, 2006 | 08:59 PM
'Shifter's Avatar
Car: 87 Z-28
Cool...can we arrange something for thursday night?
Old Sep 6, 2006 | 12:02 PM
Engine: 5.8
sounds good to me, my # is 405-7703 call any time
Old Sep 6, 2006 | 01:30 PM
  #42
joe91cam's Avatar
Car: 1991 camaro rs
Engine: 5.0
i was wondering how much for 3.73 gears and the spool or if u could direct me were to get a spool would be great
Old Sep 6, 2006 | 02:05 PM
  #43
joe91cam's Avatar
Car: 1991 camaro rs
Engine: 5.0
and wondering if u still have the dash pad and the price for the megashifter and if youre willing to ship parts
Old Sep 10, 2006 | 06:01 PM
  #44
85 REDBIRD's Avatar
Car: 1985 Trans Am
Engine: 305 carbed
pm sent on the wheels.
Old Sep 19, 2006 | 06:34 PM
  #45
84L69TA's Avatar
Car: 4 Mopars total
Do you still have the interior?
Old Nov 14, 2006 | 06:22 PM
  #46
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
seat belts
you selling the seatbelts as a whole? i need just the "receiver(buckle)" part. what color is the interior? you shipping parts? how much for the seat belt buckles? still got the turn key 327?send info on that
Old Nov 14, 2006 | 06:41 PM
  #47
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Is the steering column for sale? I'm having trouble with mine. How much?
Old Nov 19, 2006 | 10:06 AM
  #48
Engine: 5.8
column 50.00
black i will ship 30.00 to your door
sold the 327
Old Nov 19, 2006 | 11:44 PM
  #49
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
If the car came with 16-inch wheels and PBR rear calipers, I'd like to buy the "space-saver" spare.
Old Nov 20, 2006 | 03:25 PM
  #50
Engine: 5.8
drum rear
