Southern California Area Southern California Members.
Weekly Update (and more)
Old May 26, 2002 | 03:47 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Well, this saturday I pulled off the entire front end and test fitted the PA K-member. Everything fits fine, except the driver's side mount flange. We (or should I say my Father) trimmed the corner to fit. And as Jerry said, you'll need shorter bolts. We held it up in place using the shortest one of the three sets (furthest one back). It is the right lenght for all of them! Removing the struts was a ... uhm ... interesting experience. One word of recommendation, support the lower a-arm. In the rush to remove the struts, I forgot about this. No the springs didn't fly out, we still needed to compress them more. I noticed that my upper strut bearing is going, feels like sand is in it. Here is an idea, which might just expand to commerce. I am going to fab up the upper strut supports. I will have the upper bearing retainer in a quick change design and the entire support will be a much simpler design than the OEM. Currently I know of one place that makes replacements, so there could be a market for this.
As soon as I finish the brake on the "other car" I will design something up and submit the "concept" pictures for approval. As well as start (hopefully) on the jig for this and other suspension parts.
Old May 26, 2002 | 04:02 PM
BrandenCali's Avatar
Do you mean the
The um...Camber bracket? or what ever it's peices or peice is called. I seen some one that made 1 a week ago, he had bent his all up from wheel stands, even bent the headers. I donno how the coil overs turned out.
Cool you are putting on a k member eh..nice nice...Have fun..
Old May 28, 2002 | 12:44 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Mount
Have you seen this?
https://www.thirdgen.org/techbb2/sho...5&pagenumber=1
Old May 28, 2002 | 05:01 AM
Those look like they would do the trick
Looks nice.. A lot nicer than what I seen. But i did not see the finished product though, but I dont think he was making the complete set up custom like that.
Old May 28, 2002 | 03:15 PM
MRZ28HO's Avatar
Engine: was: L69
Re: Mount
Yup, I saw those. Kinda where I got the idea, but I am not going to make it out of aluminum.
Originally posted by Dyno Don
Have you seen this?
RedLeader289
May 28, 2019 01:47 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
