Southern California Area Southern California Members.
The results of two Pick-A-Part runs...
Old Jun 9, 2002 | 08:09 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yesterday (Saturday) I went to the Ecology yard in Wilmington. I got 18 sway bar mount brackets for .75 each and made a discovery (news of that discovery to follow in a separate post). I also scored a broken hatch pull-down unit. It has a broken housing, but good parts (gear nut, motor, switches, etc.) to rebuild other units. I also scored some t-top door wedge plates (Bret and I both need them for out C&C t-top converted cars). I also found a Firebird with a good headlight motor and snagged a new looking gear for Bret. Today after racing I went to Ecology in Sfe Springs. I got another 15 brackets for .50 each. I got a complete 86 power hatch pull-down unit (rebuildable). Good housing, but I suspect the gear nut is stripped (the motor was disconnected). I also got 3 gray rear hatch trim screws for GPL (sorry I dropped the 4th). I also got a 5-point racing harness for $7.95. It is missing the latch that mounts it to the roll-bar, but I can likely get spare parts. I also scored the plastic trim surrounding the C&C t-tops including the trim pieces that finish off the headliner. I could have gotten the t-tops as well, but I already have a spare set, I'm just missing the trim pieces from them. Not a bad weekend.
Old Jun 10, 2002 | 12:10 AM
BrandenCali's Avatar
good job Lon
Glad you found some good stuff. esp the hatch pull down. We need as many as you can get, an keep them in stock =) I still need to do repair work on mine again =/ ya think I need to grease it up good so it functions smoother. The darn thing just don't want to stay working.
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
