Southern California Area Southern California Members.
Don>>
Old Sep 23, 2002 | 06:37 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Don>>
What kind of gaskets are you using for the runners? I got some stock Fel-pro gaskets, I measured them and they are almost perfect, I'm actually going to have to trim some material from the gasket. Is that normal?
Old Sep 23, 2002 | 10:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Gaskets
Try and get the Accel set or Mr. Gasket. They're 1.750 Then match the runners to them. (or just a little less, like 1.670)
Old Sep 23, 2002 | 10:48 PM
89 TA's Avatar
Engine: 383/435 Cat
Do you have to order them or can I just walk in somewhere and ask for them? TIA
Old Sep 23, 2002 | 10:54 PM
Dyno Don's Avatar
Most likely have to order. Try Summit.
Old Sep 24, 2002 | 12:04 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
the accel replacement gaskets are $30 from summit. However the Mr. gasket labeled set (p/n 146, summit p/n MRG-146) is cheaper at $17. Both are stated to be 1.75 dia holes.
