Southern California Area Southern California Members.
Need to pass smog
Old Feb 17, 2003 | 01:42 PM
jobberroll215's Avatar
Car: 87 z28
Engine: 5.0
Transmission: t5
Need to pass smog
After a lot of work my car is running good but has yet to pass smog her are the latest results
Hc: 165
Co: 3.25
No: 271
The Hc and the Co are high what can i do to make the lower
thanks for any help
Old Feb 17, 2003 | 08:00 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Hc: 165
Co: 3.25
No: 271
These numbers indicate a faulty catalytic converter. (not working)
Don>>>
Old Feb 17, 2003 | 08:04 PM
Car: 87 z28
Engine: 5.0
Transmission: t5
i have just replaced the cat a few weeks ago could there be any other probles
Old Feb 17, 2003 | 08:23 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
new spark plugs, new plug wires, timing, O2 sensor, cat. all of those can affect whether or not you pass smog.
Old Feb 18, 2003 | 01:34 AM
Dyno Don's Avatar
Is the air tube hooked up?
Do you have any vacuum leaks?
These are things that will affect those numbers.
Old Feb 18, 2003 | 03:09 PM
83TransAmGirl's Avatar
Car: '83 T/A WS6
Engine: carbed 305
Transmission: 700R4 w/ shift kit
Hey Don...
Can you do Test only smogging? cause for the second time in a row I have to go to a Test Only station and I have a feeling it wont want to pass again(last time we finally took it to a carb shop and he found that one of the diaphrams broke and was sucking fuel into it)! I really need it to pass quickly and trouble free-I have the only legal car in my family!(My dads 93 BonnevilleSSEi needs to go to a test only station too but it has the check engine soon light on all the time so he hasnt passed-5 months past due! And our Suburban is 7 months past due and we cant get it to pass at all!) Im going to take it to a pre tests and see what happens...*crossing my fingers*
Old Feb 18, 2003 | 10:14 PM
Car: 1991 Firebird
Engine: 3.1LV6
I hate Test Only smogs......doesn't your Zip code have to do with whether you go to a test only center or not?
Cuz I have two zip codes I can use. My PO box and my house zip
Old Feb 18, 2003 | 10:42 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Mostly depends on your car and the engine. My Trans Am is smog test only all the time while the Toyota truck is random. The Trans Am has to go to the smog only places all the time because it is categorized as "possible gross polluter"
Old Feb 18, 2003 | 11:16 PM
Dyno Don's Avatar
No Britney, I dont have a smog shop, but I have a guy locally I go to that doesnt nit-pick.
The only way your zip code matters is if youre in a high-smog area, which is almost all of southern california. Check http://smogcheck.ca.gov/ for more info.
Old Feb 18, 2003 | 11:21 PM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
CO is to rich, HC follows it up..... As soon as you clean it up Nox will problry take off. I am a California Smog Tech, What are we working on here ?
Old Feb 19, 2003 | 10:43 PM
Car: 87 z28
Engine: 5.0
Transmission: t5
what sould i do to help it pass then any advice would be helpful
Old Feb 19, 2003 | 10:45 PM
Car: 87 z28
Engine: 5.0
Transmission: t5
the car is a 87 Camaro with a 305 ccCarb
Old Nov 6, 2013 | 08:28 PM
powerbylight8's Avatar
Re: Need to pass smog
i have 86 trans am/ carburator with smog issues. Did the basic tune up improvement. Did not pass, it had high Nos , it smoke a little before the tune up, but now it runs great, but the smell feels toxic and makes me sick. It s like weird not gas smell or exhast but head ack smell.
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
