Will this get me 1/2 second quicker
Mods after last trip to Fontana.
SLP dual cold air
SLP runners
Edelbrock base
Yank SS3600 converter
Pro-built 700r4
Global west torque arm
Global west bearing type Lca
Willwood brakes with alum hubs
P.A. K-member 4130
Tube A-arms 4130
S-10 manual steering box
Remove a/c system
Relocate batt to trunk
Fiberglass hood
Aluminum water pump
Total weight reduction is over 200 lbs all off the front end.
Jerry
SLP dual cold air
SLP runners
Edelbrock base
Pro-built 700r4
P.A. K-member 4130
Tube A-arms 4130
Remove a/c system
Fiberglass hood
Aluminum water pump
Jerry
Car: 92 RS with B4C Package
Axle/Gears: 323
Dont forget your stickers that another 1/2 sec faster
S10 steering box? no power?sounds cool when are you going to the track and try it out?
The only stickers on my car have CARB E.O. number on them.
Jerry
Originally posted by Dwayne88IROC
Are the K-members stronger then stock? How much lighter are they?
The stock K-member is 48+ lbs and the P.A. Racing unit I have is 18+ lbs so about 30 lbs lighter all off the front end and lots more room.
Jerry
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I like it!
Is there any welding involved? Is it a bolt on that can be done at home?
I really like the room. I'm thinking this would be good for the 88. How much are they?
I like it!
How much are they?
I like it!
How much are they?
It was a bolt in one day job with the motor still in the car. The hardest part was reistalling the right front brake line and getting the bolts from the hardware store.
I got my K-member on a G.P. at CamaroZ28.com it was $100 off.
Jerry
Would you mind if my (NHRA liscensed) woman drives it for one run?
