Southern California Area Southern California Members.
Mech. search
Old Jun 26, 2003 | 08:55 PM
Grimaldo's Avatar
Mech. search
Know anyone good in the San Diego area with 3rd gen's. I need some help fixing my fan problem.
Old Jun 27, 2003 | 12:01 AM
BrandenCali's Avatar
I
I suggest Dyno Don he has become a fan expert.
Old Jun 27, 2003 | 03:32 PM
rezinn's Avatar
Don is a bit of a drive from San Diego, though. What's your problem?
Old Jun 27, 2003 | 04:05 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
where in SD?
Old Jun 27, 2003 | 04:37 PM
I had some
Major fan problems, I was running on only a few cyl. Don wired the fans up with a fuse were the fusible link use to be and it fixed it temporally car ran on all 8. It began to blow 30amp fuses, So I went to the Chevy Dealer and bought a new Positive battery terminal and it had both the fusible links, new wire that runs to the alt also and to the starter it was a bit pricey but it was needed and well worth it. Don also relocated my fan switch to the base in place of the cold start sensor since the cold start was deleted with the 89 chip, So now the fan switch won't get hot and crack such as being under the manifold. So it all turned out nicely other than after all was fixed my temp gauge broke =/ My Ac works so the car runs cool still with the Ac on with every thing working properly now.
Old Jun 27, 2003 | 05:35 PM
Grimaldo's Avatar
Wheres dyno Don. I am in the coronado area. I will drive a little ways if its worth it.
Old Jun 27, 2003 | 06:14 PM
go to
The Sticky link and his adress is there..
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
