Southern California Area Southern California Members.
stupid mechanics
Old Jul 4, 2003 | 02:24 PM
demonchild's Avatar
stupid mechanics
mycar was running crappy for some time now. i decided to give it a tune up, so i got around to changing the plugs and found that the last person i took it to only changed the plugs that were visable to me, and they also happened to be the easy ones to get at. anyway, i got into changing the plugs and it took me 4 hours and A LOT of agrivation so for now on dyno don is doing my tune up's and everything else on my car. ive heard that hes trustworthy, good, etc., so dyno don, wanna give me some directions to your shop?
Old Jul 4, 2003 | 04:07 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
here you go
1207 west struck
Orange,CA 92867
714-633-5168
Old Jul 4, 2003 | 04:33 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
The last plug, the one closest to the firewall on the drivers side was easier to get from underneath the car. At least I found it easier that way. Being that I don't have a universal extension for my socket set. Would make it much easier to change the plugs too.
Luckly i had the car already jacked up when i had to change the plugs. I was doing some other work that day and said, "why not."
Old Jul 4, 2003 | 05:54 PM
demonchild's Avatar
all of the plugs were pathetically easy until you run up against the 1 cylindar and drop the plug between the starter and the engine and takes 2 hours to fish out.
Old Jul 4, 2003 | 06:14 PM
JesasaurusRex's Avatar
4 hours 2 change ur spark plugs
Old Jul 5, 2003 | 01:04 AM
demonchild's Avatar
why do you think that im NOT attempting it EVER again.
at least the car is running 500 percent better now.
also, can someone explain to me the differnce in hotter or colder spark plugs.
Old Jul 5, 2003 | 06:42 PM
**** lol id attempt it everyday if i were you, you must have taken like 25 minute breaks between each plug. Practice makes perfect, i hope that next time you do ur plugs u come online and say it took u 15 minutes. Tops
Old Jul 6, 2003 | 07:14 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
a hot plug burns (ignites) slightly hotter than a stock plug and a cold plug burns slightly colder than a stock plug.
Hot and cold plugs make a large difference in a 2 stroke engine, but not much in a 4 stroke.
Sometimes with a older engine a hotter plug will help the burn.
Unless you can "read" plugs, the color shows how the engine is burning, it is best to stay with the stock heat range. And with all the additives in gas now, reading plugs is almost impossible.
Go to sears and buy a basic std/metric socket set, then add to it as you need.
Removing the front tires helps get to some plugs.
Old Jul 6, 2003 | 10:32 PM
Guest
Guest
Posts: n/a
"Removing the front tires helps get to some plugs."
On your car. Guys with thirdgens arent so lucky
Old Jul 6, 2003 | 11:19 PM
demonchild's Avatar
i wouldnt attempt the job without the right tools. my dad has an extremly extensive tool set that he lets me use. i've never ran into a job that i had to go get a tool for. i had the swivel, deep sockets, and 3 in and 5 in extension. they were still hell. however he told me the same thing that DevilsAddvocate said...practice makes perfect.
also, the wheel wells make it impossible to gain any access to the plugs. how does it help you?
thx for the advice.
Old Jul 6, 2003 | 11:33 PM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
Originally posted by AYMAN
here you go
1207 west struck
Orange,CA 92867
714-633-5168
What's the name of the shop listed on the post?
here you go
1207 west struck
Orange,CA 92867
714-633-5168
Also do they specialize in TPI's?
Old Jul 7, 2003 | 12:11 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yeap.. first time i did a 3rdgen it took awhile... but now i can do it in around 15, 20 mins tops...
and i dont need a universal or a swivel socket.
Old Jul 7, 2003 | 05:45 PM
Guest
Guest
Posts: n/a
He has a G-body, I'm sure thats what he was thinking of. They arent the same, the wheelwell doesnt touch the framerail all the way across.
Old Jul 8, 2003 | 01:21 PM
demonchild's Avatar
g body?
what cars are G bodys?
Old Jul 8, 2003 | 02:21 PM
91Z28-350's Avatar
Monte Carlo, Regal, El Camino (82 up IIRC), Malibu, and a few others.
Old Jul 8, 2003 | 02:25 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
here you go
1207 west struck
Orange,CA 92867
714-633-5168
Oh yeah he is F body specialist. His name is Don. :hail:
Bytheway I do not the name of the shop
Lbibb
May 5, 2016 12:00 AM
djmarch
Oct 2, 2015 10:41 PM
sjorgens
Oct 1, 2015 07:54 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
