overheating!!!
overheating!!!
well just got a 89 305 v8 firebird.and the car gets hot rather fast up to 230 befoire i turn it off. had radiator flushed new hoses everything done .put a new thermostat 160.fan is working but still overheats weird thing is when i turn the ac on the temp stops climbing or it goes down that is weird.any suggestions?
would it ok to just drive with ac on all time?
p.s. anybody know any good mechanics in so cali that can help.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Does the car have a TBI or TPI? Check the temp fan switch and check to see if the air deflector is still under the radiator.
Re: overheating!!!
Regarding mechanics in So Cal, Don Lorentzen is the best. He's listed at the top of "Third Gen friendly companies" sticky.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Read the suggestions in this post:
https://www.thirdgen.org/techbb2/sho...hreadid=190676
Turning on the AC turns your fan on, which would cool it down. You probably need a lower temp fan switch to go with the lower temp thermostat. Also make sure the radiator is clean and there is no debris between it and the AC condensor.
