Southern California Area Southern California Members.
Lacr on wends?
Old Sep 29, 2003 | 02:22 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
Lacr on wends?
hey anyone going to lacr on wendsday? cause i'm going to be going i want to get some stock times for my gta. i'm going up there with acouple other car, 71' camaro ss, eclipse gst, and an eclipse gsx. how busy is lacr on wendsdays? what do u think i will run all i have is !cats and a flowmaster, so stock lol. i'm thinking like 14.3.-14.7 maybe. How much do u think the 3.23 and the alum drive shaft will help? should i through on a open k&n filter or just leave the stock one?
Old Sep 29, 2003 | 02:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
14.3 - 14.7 at a sea level track, but LACR is at 2900'. Your times will be more like high 15's like mine were... Good luck and look out for the black 2001 Camaro SS that prowls up there.
Old Sep 29, 2003 | 02:30 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
that's right i forgot lacr is way up there. what little free mods should i do before i go?
Old Sep 29, 2003 | 12:36 PM
12secSS's Avatar
LACR on wednesdays is usually not very busy. You'll see about 10-20 domestics, and 20-25 imports, some 10 second cars and street bikes. Chances are you will run about low 16s to high 15s as Kevin said.
Don't sweat the 2001 Black SS, it used to prowl up there, not any more. My bone stock run up there in my SS was 13.8 @ 98, with a 2.4 60' ... I was able to improve with to a best of 12.75 @ 105 with a 1.74 60'. This track, if you seriously learn, hooks as good as Pomona. I know this track very well and can tell when it is going to hook and when it is not. Don't expect decent numbers if this is your first time out there.
Old Sep 29, 2003 | 09:19 PM
Kevin91Z's Avatar
Crank your initial timing up to 10 degrees, and make sure your air filters are clean.
Old Sep 30, 2003 | 04:09 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
just for the hell of it should i through some 104 octane gas in my car? i can get it it for free. my friend bought 104 but he needed 110. i think i am going to bump up my fuel pressure to if i have time.
Old Sep 30, 2003 | 09:19 AM
Kevin91Z's Avatar
No, you dont need high octane gas for racing at altitude. In fact it might hurt you. Straight 91 should be fine. That's also why I suggested advancing the initial timing, as lean air likes more timing. If it pings just back off the timing.
Old Sep 30, 2003 | 11:10 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
And don't up the fuel pressure....lower it. No air=to much fuel
Old Sep 30, 2003 | 11:22 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
thanks guys you have been very helpful
Old Oct 2, 2003 | 02:25 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
my times were pretty decent. i beat a 95 formula lt1 and had a good run with a 2001 mustang GT.
first run ever..
rec-1.035
I1 : 2.280
I2 : 6.446
I3: 9.918
Mph (I3) 70.570
I4 : 12.910
e.t. 15.755
mph : 77.688 was shifting through gears and left in second i think.
second run i red lighted, 3rd was 15.633 @88.997 60ft was 2.6
beat formula this run
4th was 15.444 @88.384 2.317 60ft mustang gt ran 15.166 at 91.955
LAFireboyd
Jul 26, 2015 08:22 PM
CBR1000RR
Jun 27, 2007 03:08 PM
97formula
May 27, 2007 11:34 PM
crazy8s
Dec 18, 2003 05:51 PM
MRZ28HO
Oct 24, 2002 10:26 PM
