Southern California Area Southern California Members.
Hiflow CATS?
Old Feb 9, 2005 | 02:04 AM
89GTA2LV's Avatar
Car: 89 Trans AM GTA
Engine: 5.7L
Hiflow CATS?
I was thinking about adding hiflow Cats to my 89 GTA. I already have the 3'' flowmaster exhaust but its from the CATS back. Would replacing the stock Cat's make a bid difference? If so, what kind of difference?
Thanks in advance for your advise
Old Feb 9, 2005 | 10:12 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
All cats are hi-flow today, they have what is called a monolythic core. The only way it would benefit you is if you change the manifolds to headers and a larger y-pipe.
Edit:
Forgot to mention...you really need to get rid if that y where the pipes join after the cats (really bad for performanve).
Old Feb 9, 2005 | 05:38 PM
1fsstgta's Avatar
Car: F-Bodys
Engine: 355
Transmission: shifting
If your cat on your car is stock then yes I would change it. You will notice a little more topend but your sound with deffinetly change for the better
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
