Southern California Area Southern California Members.
smog help
Old Apr 27, 2005 | 03:02 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
smog help
I just bought a zz 383 from jegs and i really dont think it will pass smog because there is no carb numbers except for my hooker headers and my superram. I bought a new edlebrock lower intake that just came out to fit the vortec heads so i could use the super ram intake. My question is, does anybody know someone to pass this car for me. I will be using all smog parts including cat. so it will appear emissions legal.
bryan
Old Apr 27, 2005 | 03:09 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
What is the cam?
Sounds like you still have the EGR system hooked up correct?
I would take it to a station and pay for just a test, if they ask you for a reason say that you are thinking of selling your car and just want a smog certificate to show prospective buyers. A brand new motor should burn clean especially if all the smog components are hooked up but I would say the major factors will be the cam and heads. What kind of chip are you running? - That's going to make a difference as well.
Old Apr 27, 2005 | 10:44 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yeah...down here if everything is there.
Old Apr 28, 2005 | 12:56 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
the cam is a powermax hydraulic roller cam
Lift: .509''/.528''
Duration: 284°/292°
and the heads are
Material: Aluminum
Intake Runner Volume: 210cc
Combustion Chamber Volume: 62cc
Valve Diameter: 2.00'' Int./ 1.55'' Exh.
Spark Plugs: Angled
and yes i am running the edelbrock vortec manifold with a super ram intake it has an egr too. the engine arrives at my house may 12th it was on backorder at jegs.
Old Apr 28, 2005 | 11:34 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What heads are those, the Fast Burns? They dont have the EGR passages in them, so you'll need to make something like the Corvettes have, running from your headers.
Corvette:
http://para.noid.org/~thresher/images/albums/031001/
My car:
http://para.noid.org/~thresher/images/albums/021701/
Old Apr 29, 2005 | 11:18 AM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
A brand new motor will burn somewhat clean, but it won't burn as clean as a motor that's been fully broken-in since the seals won't have seated and will be letting a little oil through.
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
