Southern California Area Southern California Members.
Help
Old Aug 19, 2005 | 06:13 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Help
I just got my freshly rebuilt motor dropped in and running and drove it to the trans shop to have the pressure checked like that told me to well when i got there I popped the hood and there was oil all over the passenger side of the motor the oil dipstick came out about an inch and sprayed the motor with oil what could cause all that pressure it only happened when I drove it on the highway for 40 miles it doesn't do it at a ideal
Old Aug 19, 2005 | 06:23 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
It could possibly have an oil filter mount without a pressure bypass valve, which would cause the pressure to be really high.
Have you checked your oil pressure? What's it reading when warm and idling? What's it reading while on the highway?
Old Aug 19, 2005 | 06:29 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
the pressure is 30lb when warm and at an ideal and 60 when ever i touch the gas
Old Aug 19, 2005 | 10:38 PM
Russ-So Cal's Avatar
Until the rings seat, you may have some blow by with crankcase pressure that is blowing out the oil. Once the rings seat, you should have a nice crankcase vaccuum if the engine is built right.
Old Aug 20, 2005 | 01:21 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
That cant be it I put chrome molly rings in they never seat they ware the cylinder wall
Old Aug 20, 2005 | 02:29 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I did a compression test yesterday it came out like this.
cylinder 1=175 psi 2=170 psi 3=175 psi 4=165 psi 5=160 psi 6=165 psi 7=165 psi 8=160 psi.
Old Aug 20, 2005 | 07:39 PM
Actually they do in a sense "seat". In effect the cylinder walls will seat to the rings, maybe. Cummins diesels are famous for having difficulty getting the rings to seal because they run chrome moly. I wouldn't do a taredown yet, but if the car continues to use a lot of oil and doesn't leak it, you may need to hone and rering it.
Old Aug 30, 2005 | 11:18 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I got it number 5 and 6 pistons broke just like #3 did back in April so its time for 8 new pistons she will be running by Friday
Old Aug 31, 2005 | 03:50 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Just as an FYI, there's no such thing as "chrome-moly" piston rings. There are chrome rings and there are moly rings, but no chrome-moly. What you are really referring to is the coating that's on the ring. Piston rings are either cast-iron or steel and can have a chrome or a moly coating.
Since people are used to talking about chrome-moly when it comes to other parts, it's not uncommon that the term gets incorrectly applied to piston rings.
http://www.hastingsmfg.com/Service%2...menclature.htm
http://www.hastingsmfg.com/service_tips.htm
Old Sep 1, 2005 | 10:08 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Really thanks for telling me something that I already knew. FYI next time give me some input on the problem I was having not just some bull sh*t to boost you post count. Anyway thanks Mike and Russ for the help.
Old Sep 2, 2005 | 01:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Fine, with that attitude we wont help you out next time at all.
Old Sep 2, 2005 | 08:55 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
however that was a learning experance for me! Thanks for the info Kevin91Zl
