Southern California Area Southern California Members.
Help!
Old Sep 1, 2005 | 10:48 PM
DA 89 CAMARO's Avatar
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
Help!
Doe's anybody know of a spot where i ca go and get my car tuned on the spot.do they exist?
Old Sep 1, 2005 | 11:02 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
The days of Tuneup Masters is long gone! Try Dyno Don . You'll have to get in line with others .
Old Sep 2, 2005 | 01:18 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What do you mean by getting your car tuned on the spot? You mean, get a tune-up? Most of that stuff like changing the spark plugs, wires, cap and rotor, O2 sensor, and fuel filter is stuff you can do in your driveway with a basic set of hand tools.
Check the tech articles on this site, there are quite a few good ones about general maintanence and upgrades.
Old Sep 2, 2005 | 06:14 PM
Car: 89 RS,97 Z28
I was talking about having the car's computer tuned.sorry for not being specific
Old Sep 2, 2005 | 08:53 PM
Russ-So Cal's Avatar
Why do you need yor computer tuned? If the car is stock, you don't need a custom chip. If it is modified, Kevin and Don do custom chips, but they need more info than you have given.
Old Sep 3, 2005 | 12:26 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
And it takes time to get a 'good' chip created, basically it's a test and tune type of process. The 'on the spot' type tuning can really only be done by yourself with your own complete tuning setup.
Old Sep 6, 2005 | 09:44 PM
Car: 89 RS,97 Z28
I just got my car back I had cam,pushrod's,lifter's,rocker arm's,head's,timing chain and gears,and a electric water pump.I'm still driving it as is but it definitely need's a custom chip.
