I was watching one of the hot rod type programs on tv and they installed a 4L60e trans in an older Camaro. They got a stand alone computer from G.M. Performance Products to work the trans. It looked like it was about the size of an MSD ignition box. I don't know what the cost is or if it will work with tpi engines or if it is just for old school carb motors, but it looked like a possible alternative to going with the complete rewiring needed to run a 93 model lt1 computer in our cars to get the advantages of the electronic controlled transmissions in our cars.
I'm considering the one form TCI for my upcomming 4L60E project. I believe it is cheaper. It will work with TPI engines and is easier to do than the carb as all the needed signals are already there. With the carb I believe you have to install a TPS switch. You do with the TCI version.
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:27 Times in 23 Posts
Actually the 94+ f-bodies have 4L60E's. The 93 used a regular 4L60 like ours.
