Southern California Area Southern California Members.
Mr.300
Old Oct 10, 2007 | 05:15 PM
Guest
Guest
Posts: n/a
Mr.300
Don I need a favor, I need you to remove that plug from the 2nd 02 location, so we can get a wide band in there. I tried my best with my strongest weakness and can't get it to Budge.
Old Oct 10, 2007 | 08:32 PM
Guest
Guest
Posts: n/a
Re: Mr.300
Got it out Don. Was pretty hard but I got it. I put a 02 sensor in there instead of that Plug.
Old Oct 10, 2007 | 08:38 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: Mr.300
Where's the 2nd location at? I replaced the one on the driver side manifold, but didn't know there was a 2nd.
Old Oct 10, 2007 | 10:11 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Mr.300
Custom Dyno Don installation.
Old Oct 10, 2007 | 10:31 PM
Guest
Guest
Posts: n/a
Re: Mr.300
Yeah for Ecu tuning with wideband you have to have another location. Because if you put a wideband in your existing o2 location you will be running in open loop.
Now with a Dfi that's not the case. You can option of open loop closed loop and you can remove the single heated o2 and put the wideband there, I hope Im correct there. Should be.
Old Oct 11, 2007 | 10:38 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Mr.300
For those of you wondering why he called me out as "Mr. 300"
On August 7th I bowled my first perfect "300" game.
Old Oct 14, 2007 | 11:59 PM
TELLEZ's Avatar
Re: Mr.300
Really? Thats very cool.
Did you have to buy your own ring or does the bowling alley give it to you as soon as the confetti and balloons settles?
Congrats!
Old Oct 17, 2007 | 11:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Mr.300
You have to buy your own ring, now.
Old Oct 18, 2007 | 10:22 AM
Dyno Don's Avatar
Re: Mr.300
Congrats!
They do give you a ring although is a cheap thing.
I chose to purchase the gold because it was my first.
They used to give a $100 but not anymore.
