Southern California Area Southern California Members.
flywheel
Old Nov 12, 2007 | 10:39 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
flywheel
anyone know where i can get a flywheel for a decent price? I have an 87 350 with a t5
Old Nov 12, 2007 | 05:17 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: flywheel
McLeod had some factory ones on close out awhile back.
630-2764
Old Nov 12, 2007 | 05:21 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel
thanx a lot don I'll give them a call but what area code is that? seeing that you're in orange is that 714?
Old Nov 12, 2007 | 05:28 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
Re: flywheel
im from across the country, but i got mine at advanced auto parts for about 80 bucks. if u dont have advance auto parts stores out there check with napa. i think they want about 120 for them.
Old Nov 12, 2007 | 05:32 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel
thanx i just checked with autozone and they want 60 dollars with core. Now only to figure out which engine i have i know its a 350 1 piece rear main seal internally balanced and a t5 tranny. Any idea what car came with this setup so I can order it since autozone only lets u look up parts by make and model? oh and i think its a 168 tooth flywheel that i currently have but not 100% sure i'll count them this weekend when i pull out the flywheel
Old Nov 12, 2007 | 05:40 PM
Dyno Don's Avatar
Re: flywheel
It's 153 tooth factory, but don't tell them 350 as there are none.
The 305 is the same thing.
Old Nov 12, 2007 | 05:44 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel
but my engine isn't factory which is why i asked. I know its an 87 350 but the guy i bought it from didn't know what car it came off of. So if i buy a 153 tooth flywheel what do i need to make sure of so that it will bolt on with no problems? just that its for a 1 piece rear main seal and thats it? Does it matter if I order a 153 or 168? The problem I had now was that the starter grinded off some of the teeth on the flywheel so now the starter just spins without engaging the flywheel consistantly but it does engage once in a while and fires right up. its a powermaster high torque starter that works with 153/168 flywheels.
Old Nov 13, 2007 | 12:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: flywheel
It will be a 153 tooth flywheel no matter what. 168 tooth is for big blocks and will not fit inside a T5 bellhousing.
Old Nov 13, 2007 | 09:56 AM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel
ok thanx thats what i wanted to know
Old Nov 13, 2007 | 10:03 AM
Dyno Don's Avatar
Re: flywheel
If that is the only problem, they can change the starter ring.
It just presses on.
By the way, a lot of those starters cause that problem, get an LT1 starter.
Old Nov 13, 2007 | 10:12 AM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel
well it looked like it grinded some of the teeth of the flywheel off. No teeth are missing it just had metal shavings on it. I'll drop by and pick up an LT1 starter and see if that fixes the problem thanx
Old Nov 13, 2007 | 06:29 PM
Dyno Don's Avatar
Re: flywheel
If the teeth are bad you'll just ruin the new starter.
Old Nov 13, 2007 | 10:58 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel
Ok yeah it seems the flywheel needs to be replaced. Does anyone know what year camaro comes with a one piece rear main seal so i can order a flywheel from that car
Old Nov 14, 2007 | 11:54 PM
Kevin91Z's Avatar
Re: flywheel
'86 and newer are one piece rear main seals.
Old Nov 16, 2007 | 12:34 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: flywheel
not completely right, my sbc 400 had 168 tooth.
Old Nov 16, 2007 | 07:06 PM
Dyno Don's Avatar
Re: flywheel
Yes, completely right there were no '86 400's
And...most of the 400's were big cars or trucks.
That's why they had 168's.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
