Southern California Area Southern California Members.
need help!!!.
Old Aug 16, 2008 | 11:51 PM
bigc4rmdacityla's Avatar
Car: 1988 camaro iroc -z
Engine: 5.7 350
Transmission: 700 r4
need help!!!.
Does any one know a good place that rebuilds engines in socal, thnx
Old Aug 17, 2008 | 11:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: need help!!!.
Dyno Don is the only one we trust, but his waiting list is a mile long, because he's so good.
What kind of rebuild are you looking for?
Old Aug 29, 2008 | 03:45 PM
Engine: 5.7 350
Re: need help!!!.
jus a general rebuild, because it has 146,000 miles
Old Aug 30, 2008 | 10:12 AM
Russ-So Cal's Avatar
Re: need help!!!.
Have you considered swapping in a G.M. crate long block? It would probably cost about the same as a rebuild, but you would not have to wait for a machine shop to do all of the machine work on your engine. I think Paul, f1ls1, does engine replacement in his garage, to my knowledge he just doesn't do total rebuilds. Most of the engines Don builds are not stock.
Old Aug 30, 2008 | 11:00 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: need help!!!.
Mine has 216,000 and still runs well. What wrong with yours?
Old Sep 2, 2008 | 05:34 PM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
Re: need help!!!.
wow mine has 198.000 miles and still runs great!!! but i think its recommended to rebuild your engine every 200.000 miles you only have 140 something thousand miles. i like that idea about just grabbing a GM crate long block!!! sounds good! think ill do that when its my time.
