I need help
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
I need help
I have an 89 305 iroc and the harness is ripped up wires everywhere sliced diced and everything. I also have a brand new 86 harness but I've seen the plugs to air pump ,alt,and all the relays ,acc plugs different online can I cut my plugs from the 89 wires slice together? Is the c1oo connector different from 86 to an 89? help me I've been trying to read things about wiring
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: I need help
Get ahold of Dyno Don. He is an expert in the area of wiring harnesses among other things. He can set you straight or probably fix what you have for a nominal fee.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: I need help
DynoDon installed my wiring harness when my 91RS got swapped to an L98. Also try F1LS1, he can help you out with that too (he did the engine swap itself)
