Southern California Area Southern California Members.
Passed smog test........barely
Old Nov 26, 2010 | 06:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
With 1 point to spare.Failed the first attempt.Purchased-1 bottle Lucas octane booster, new rotor.Retarted the timing 2 degree,raised idle speed & leaned idle mixture a bit.That HC# was 133 PPM last smog test!My #s were lower across the board this time Vs last, but because Ca lowered HC to 93 PPM i failed....BASTARDS.
1st try- 15mph
......max/Avg/meas
HC: 93/51/114
CO: .57/.16/.47
NO: 788/465/407
25 mph
HC: 75/39/74
C0: .43/.11/.14
N0: 669/387/105
2nd try- 15mph
HC: 93/51/92
C0: .57/.16/.27
N0: 788/465/462
25 mph
HC: 75/39/74
C0: .43/.11/.13
N0: 669/387/31
Old Nov 26, 2010 | 06:59 PM
Guest
Guest
Posts: n/a
Re: Passed smog test........barely
Originally Posted by 84 1LE
but because Ca lowered ....BASTARDS.
Yep, gotta love this state. Cant add devices, cant swap to "illegal" parts even if you make them just as good or better than stock, but they can lower the standards to pass!
Glad to hear you were able to pass.
Old Nov 26, 2010 | 07:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I dont know how they get away with it.That $hit should be illegal.My car is certified by 84 EPA standards & it surpasses them, yet still thats not good enough!
I used to care i was passing smog the legal way, but if Ca wont play fair.Why should i.
Old Nov 26, 2010 | 07:17 PM
morganrush1974's Avatar
Car: 92 T/A Convertible
Engine: 5.7 (L98)
Transmission: WC T-5
Axle/Gears: 3.27 LSD
congrats!
Old Nov 26, 2010 | 09:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree. Congratulations. As I see it as long as it blows clean that should be it.
jaridjohn
Oct 5, 2015 07:01 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
