Southern California Area Southern California Members.
Failed smog. could use pointers
Old Aug 6, 2012 | 04:48 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
failed my smog but it was just the HCs on both 15 and 25 mph test.
tech told me to get cat swapped out and the maf aswell. before i go that route i wanna see if anyone could spot things on the print out that could tell me what sorts of fixing i need.
i passed last year around march with everthing it had with the exception of a cold air intake retrofitted with the stuff from the stock one ie: sensonrs and such and a new magnaflow exhaust. old one was rusted out and it passed oddly enough. i didnt think i needed to seafoam it since i had a top end rebuilt a month ago. i drove around in it for around 10 miles before i went to the station. to get it warm.
so with that should i put the old intake on and try again?? or what else should i try. i have only like a week to do it since my tags technically expire on the 18th.
Old Aug 6, 2012 | 07:22 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Failed smog. could use pointers
Just pay the registration so you won't get late fees and you will have more time to figure out the smog issues.
Old Aug 6, 2012 | 08:41 PM
Mailman818's Avatar
Engine: 2.8L V6
I can do that? last year when i tried that they said they needed the smog certificate to be able to register it. other then that they didnt let me pay anything until the smog was submitted
Old Aug 6, 2012 | 09:23 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Yes you can. I did it in January. I know of several people that have done it. You just won't get the sticker, but at least you won't have late fees.
Old Aug 7, 2012 | 10:46 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
^^ He's right.
Old Aug 7, 2012 | 10:51 PM
Mailman818's Avatar
Engine: 2.8L V6
interesting.... i guess if i cant find out what it is ill just try that.
Old Aug 10, 2012 | 04:40 PM
Mailman818's Avatar
Engine: 2.8L V6
I ended up getting a cat since it was going to be free and i cleaned the maf. ended up passing with flying colors
Johnny*G
Oct 20, 2015 12:37 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Sep 19, 2015 09:35 AM
