Southern California Area Southern California Members.
Poor little piston
Old Oct 8, 2017 | 10:26 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Poor little piston
It looks like a tiny cutting torch was used.
Old Oct 9, 2017 | 02:53 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Poor little piston
What is the story behind the piston?
Old Oct 10, 2017 | 10:22 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
That was a piston in my stock 305 with a 150 shot of N2O.
Then this motor trashed the T5.
Attached Thumbnails Poor little piston-front_good_1.jpg   Poor little piston-t-5_broken.jpg
Old Oct 11, 2017 | 12:35 PM
Car: 1989 GTA
Engine: 369 TPI
That sounds like something JerryWho would do.
Old Oct 11, 2017 | 10:41 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
were you running any kind of ignition timing retard like a MSD box to pull out timing when N2O was flowing? or did you just have a wet/dry shot on standard timing ?
Old Oct 12, 2017 | 03:06 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
I used a wet shot and standard timing. I never expected the stock 305 motor would last.
Nitrous on a stock 305 is only temporary and kind of a waste. I used it to justify the need to stroke it
Old Oct 15, 2017 | 06:44 AM
6998poncho's Avatar
Car: 1998 Firebird Formula M6
Engine: LS6 installation finished 8-17-2011
Axle/Gears: Stock 3.42 Ratio
Are you the Dwayne that used to live in Los Alamos? I was wondering what happened to you. Rich in Santa Maria.
Old Oct 15, 2017 | 01:55 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
Yes, Hi Rich. I relocated to Lake Forest in south Orange county.
I'm still cooking tri-tip and tattooing asphalt.
Old Oct 15, 2017 | 02:19 PM
6998poncho's Avatar
PM sent.
