Southern California Area Southern California Members.
Where is this ESC (knock module) located
Old Mar 14, 2002 | 05:25 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I thought I knew what it was but now I'm not sure any more.
I'm suppose to replace my knock sensor and Electronic spark control from my 305 to a 350 for better knock control on my new larger motor.
I know the knock sensor that plugs into my engine but I don't know where this ESC is located.
Help?
Correct me if I'm wrong but I think the part numbers are:
knock sensor - 10456288
ESC - 16128261
Old Mar 14, 2002 | 08:17 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The ESC is a flat square unit on the driver's side engine compartment by the fan relays. It has a large 5 wire plug going into it. You dont have to change it, just the knock sensor.
Old Mar 15, 2002 | 11:10 AM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
But the part numbers are different between a 305 and 350.
305
Knock sensor - 10456287
ESC module - 16126761
350
Knock sensor - 10456288 $40.35
ESC module - 16128261 $74.19
If your experience says they work then I'll go with it.
The knock sensor is the cheaper one too.
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
tonys91rs
Sep 2, 2015 07:07 PM
RyanJB
Sep 2, 2015 01:27 PM
