1982 - 1992 Chevy Camaro Front Suspension Steering Linkage Kit
Is the steering on you Camaro or Firebird getting sloppy? Have you realized it's getting harder to keep your vehicle going in a straight line? If you've answered "yes" to either of these questions, it may be time for our steering linkage and suspension kit.
Components included as shown:
(1) Center link
(1) Idler arm
(2) Lower ball joints
(2) Inner tie rod ends
(2) Outer tie rod ends
(2) Tie rod adjuster sleeves
(2) Front sway bar links
Remember whenever you are replacing any front end or steering components you should have your vehicle professionally aligned as soon as possible.
When installed correctly and an alignment performed, the components in this kit can also reduce uneven tire wear and in some cases you may even see a slight improvement in gas mileage!
1A Auto Parts Offers FREE SHIPPING On All Orders.
(1) Center link
(1) Idler arm
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: 1982 - 1992 Chevy Camaro Front Suspension Steering Linkage Kit
i know this is a old post but does this kit come with the rubber ball joint and tie rod bushings or poly and if its rubber can i put poly on them... is this a factory replacement or a upgrade.... very interested in buying this in july...
These have rubber bushings on them just like the factory ones did. You may be able to swap on poly bushings, but not 100% sure.
1992 Trans Am
May 10, 2023 07:19 PM
