1982 - 1992 Pontiac Trans Am Headliner SET for Models with T-Tops
CLICK ON THE LINK BELOW FOR CURRENT PRICES
This is a complete headliner-sun visor-and sail panel set for cars with T-Tops. The set includes our assembled molded headliner, a pair of sunvisors and a pair of rear sail panels with speaker cut-outs.
The headliner is molded ABS plastic backed interior headliner. This is a great reproduction which is much improved in materials over the original. The shell is made of molded ABS plastic which will not absorb moisture like the paperboard original. A nylon padding is used which lasts much longer and does not granularize. The result is a great looking product that is designed to outlast the original.
This set only fits models that came with factory (Fisher Body) installed T-Tops. Does not fit aftermarket T-Tops that were installed by C & C (Cars & Concepts). To determine which top style you have, remove one of the tops and measure the side that tucks into the center support section of the roof. Factory, or Fisher, tops will measure 30 1/4" while the C & C tops will only measure 28" long.
Available in these colors:
1559 Black
2001 Graphite
1755 Light Saddle
1789 Medium Beechwood
1787 Briar Brown
1666 Claret (Burgundy)
1611 Carmine Red
1714 Maple
2092 Navy Blue
1785 Royal Blue
1810 Medium Dark Grey
1833 Russet
Please note: The sail panels attach with special velcro kit supplied. Does not reuse old hardware.
Add the color desired in the note field of the order
To View Foam Back Cloth color samples Click Here.
These headliners ship UPS 70LB rate. The headliners are rolled up to fit in to the box. You must let them retake their shape over a 24-hour period before you install them. Please allow 2-3 Weeks for delivery as they are custom made to order.
ABS backed headliners are made to order. Please allow 2-6 weeks for delivery.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
