1982 - 1992 Chevy Camaro T-Top Seal Set
This weatherstrip set consists of reproduction weatherstrips. Made with fine grain rubber and correct molded ends.
This kit comes with:
A pair of door seals
A pair T-Top Body seals
A pair T-Top outer edge seals
A pair of outer window sweeps
A pair of inner window sweeps with molding
A rear hatch seal
Backed by manufacturer's limited 10 year warranty
This kit fits Factory T-Top models only.
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side the tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES.NO HIDDEN PACKAGING FEES.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
