1982 - 1992 Chevy Camaro Weatherstrip Seal Set for Cars with T-Tops
CHECK HERE FOR GREAT PRICING 1982 - 1992 Chevy Camaro Weatherstrip Seal Set for Cars with T-Tops
FREE SHIPPING ON ALL ORDERS!!!
This Aftermarket replacement weatherstrip kit includes the following pieces:
T-Top Roofrail Seals: Seal the perimeter of the T-Top, and the front/rear of the side glass to the body of the car.
T-Top Out Edge Seals: Seal the outer edges of the T-tops to the side glass.
Door Seals: Seal the back, bottom, and front of the doors to the body of the vehicle.
Hatch Seal: Seals the Hatch to the body of the vehicle.
Triangle Seals: The seals that attach to the triangles on top of the door
If your weatherstripping is causing leaks allowing damaging rain in, then this weatherstrip kit is for you. Why not replace your old, hardened, rotted seal with this new, ready to install weatherstrip set.
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side that tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
