1982-1992 Chevy Camaro HOOD Lift Support PAIR for Models that use a STEEL HOOD
CHECK US OUT HERE FOR GREAT PRICES 1982-1992 Chevy Camaro HOOD Lift Support PAIR for Models that use a STEEL HOOD
FREE SHIPPING IN THE LOWER 48 STATES!!!
Is your hood not staying open anymore? The problem could be the lift supports mounted from the fenders to the hood. These get weak over time and require replacing. No need to lose money at the dealer for this simple do it yourself replacement. Our lift supports are just what you need to allow your hood to stay open again!
Each hood strut has the following specifications:
Buyer will receive a PAIR that fits both the LH (driver) & RH (passenger) sides
Correct for vehicles with a steel hood
Replaces dealer part number: 14019157
100% tested prior to leaving the factory
Gas-Charged
Built to strict quality control standards
Commonly called "Prop Rods" by GM
Does not fit models with a plastic or fiberglass hood
This is for a pair of supports. We recommend replacing them in pairs.
Please note: You may need to use original mounting hardware to mount them.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Gas-Charged
1 Year Warranty
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
sailtexas186548
Feb 29, 2016 08:40 AM
Vintageracer
Aug 11, 2015 08:13 PM
