1982-1987 Chevy Camaro Front Brake Pad & Rotor Kit Semi-Metallic
VISIT US HERE FOR GREAT PRICES 1982-1987 Chevy Camaro Front Brake Pad & Rotor Kit Semi-Metallic
FREE SHIPPING IN THE LOWER 48 STATES!!!
Hearing squeaking noises from the wheels? This may be the wear tabs on the brake shoes saying, "it is time for replacement." Aging brakes can also result in a pulsation from the brake pedal or long stopping distances. Brakes should be inspected every 10,000 miles or any time the tires are removed. They may need frequent replacement such as every 20,000 miles if used in stop and go traffic. Brakes can last longer if the vehicle is used primarily for long highway trips.
Kit specifications:
Includes 2 front rotors & a front brake pad set
Fits Driver & Passenger Side Front
Rotors with 5 lugs
Semi-Metallic brake pads
No core charge
Direct replacements
This front brake pad & rotor kit makes a great replacement and has an excellent value over the price of dealer brake pads & rotors.
Note:
The rotors do not include wheel bearings or seals. You will need to reuse your originals.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Kit specifications:
Rotors with 5 lugs
No core charge
Direct replacements
Note:
1 Year Warranty
Zachattack0925
Aug 12, 2015 09:52 PM
