1982-1992 Pontiac Trans Am T-Top Weatherstrip Seal Kit (GM)
VISIT US HERE FOR GREAT PRICES 1982-1992 Pontiac Trans Am T-Top Weatherstrip Seal Kit (GM)
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!!
This replacement weatherstrip kit includes the following pieces:
GM T-Top Roofrail Seals: Seal the perimeter of the T-Top, and the front/rear of the side glass to the body of the car.
GM T-Top Out Edge Seals: Seal the outer edges of the T-tops to the side glass.
Aftermarket Door Seals: Seal the back, bottom, and front of the doors to the body of the vehicle.
Aftermarket Hatch Seal: Seals the Hatch to the body of the vehicle.
If your weatherstripping is causing leaks allowing damaging rain in, then this weatherstrip kit is for you. Why not replace your old, hardened, rotted seal with this new, ready to install weatherstrip set.
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side that tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
10 Year Warranty
This item is backed by a manufacturer's 10 Year Warranty. In the event this item should fail due to manufacturing defects during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
10 Year Warranty
Car: 1982 Trans Am Recaro
Engine: 305 V8 LU5 CFI TBI
Transmission: TH200C
Re: 1982-1992 Pontiac Trans Am T-Top Weatherstrip Seal Kit (GM)
Who do you recommend for installing? Do you have preferred installers?
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
I'llrocya
Feb 2, 2016 11:43 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
