VISIT US HERE FOR GREAT PRICES 1982-1992 Chevy Camaro Molded T-Top Headliner Set
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!!
This is a complete headliner-sun visor-and sail panel set for cars with T-Tops. The set includes our assembled molded headliner, a pair of sunvisors and a pair of rear sail panels with speaker cut-outs.
The headliner is molded ABS plastic backed interior headliner. This is a great reproduction which is much improved in materials over the original. The shell is made of molded ABS plastic which will not absorb moisture like the paperboard original. A nylon padding is used which lasts much longer and does not granularize. The result is a great looking product that is designed to outlast the original.
This set only fits models that came with factory (Fisher Body) installed T-Tops. Does not fit aftermarket T-Tops that were installed by C & C (Cars & Concepts). To determine which top style you have, remove one of the tops and measure the side that tucks into the center support section of the roof. Factory, or Fisher, tops will measure 30 1/4" while the C & C tops will only measure 28" long.
Available in these colors:
1559 Black
2001 Graphite
1755 Light Saddle
1789 Medium Beechwood
1787 Briar Brown
1666 Claret (Burgundy)
1611 Carmine Red
1714 Maple
2092 Navy Blue
1785 Royal Blue
1810 Medium Dark Grey
1833 Russet
PLEASE NOTE: THE SAIL PANELS ATTACH LIKE ORIGINALS. PLEASE REUSE OLD HARDWARE.
Add the color desired in the note field of the order
To View Foam Back Cloth color samples Click Here.
These headliners ship UPS 70LB rate. The headliners are rolled up to fit in to the box. You must let them retake their shape over a 24-hour period before you install them.
Returns Note:
Headliners are custom made to order, and because of this they are non-returnable. If you are unsure of which color is correct for your specific vehicle, please contact us before purchasing and we can send physical color samples out to you.
Shipping Time: This item is custom made to order and will take 2 to 3 weeks for delivery.
VEHICLE FIT
1982-1992 Pontiac Firebird Molded T-Top Headliner Set
1982-1992 Pontiac Trans Am Molded T-Top Headliner Set
1559 Black
2001 Graphite
1755 Light Saddle
1787 Briar Brown
1611 Carmine Red
1714 Maple
2092 Navy Blue
1785 Royal Blue
1833 Russet
Returns Note:
VEHICLE FIT
