STB touching TPI ?
Car: 1987 Camaro Z28
STB touching TPI ?
Hey Guys,
I noticed the other day that my Kenny Brown STB is just barely touching my TPI intake plenum. I have an 87 Z28 with a 305. I can sometimes feel alot of vibration from the steering wheel. Should I put something under the mounts of the STB to raise it up some?
Thanks in advance.
Thanks in advance. Supreme Member
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
You might want to shim it with some stainless steel washers to give you more clearance.
That's why I went with the Hotchkis STB. The height is adjustable and it will also clear the SuperRam when the time comes.
Thanks for the input
Thanks guys.
I went ahead and place some large washers under the mounts on the strut towers. This was exactly what I needed to do. I no longer hear an annoying vibration. I appreciate you guys taking the time to respond to my question.
:hail:
:hail:
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
My Jamex STB is adjustable to avoid this problem. If it was almost touching the TPI when it was just sitting, I can only imagine what it was doing when the motor was torqueing, bumps, cornering, etc!
Sanjay
Aug 12, 2015 03:41 PM
