cheap rear disc conversion?
Old Apr 17, 2002 | 06:55 PM
Killerkamaro's Avatar
Does anyone know a cheap rear disc conversion? I don't want to swap the entire rear end on my 92 RS (just put posi and gears in there.) Is there any way I can bolt on a system from a donor car? Also, I've seen some rear disc brackets on ebay. What do they do? Any information is helpful.
Old Apr 18, 2002 | 02:17 AM
poncho9789's Avatar
Scavenge your local junk yards to get all the brackets and calipers then take the calipers to your local parts store and buy rebuilt calipers if you arn't capiable of rebuilding them yourself. The only things you will need other then that is the brake lines. There is a tech article on this site that outlines everythign that you will need to make the swap to rear disks. good luck
Old Apr 18, 2002 | 02:16 PM
Camaro_hunter_d's Avatar
LS1 swap. In tech section.... should cost around 2-250.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
