RS to IROC Swaybars
Old Apr 20, 2002 | 07:16 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
RS to IROC Swaybars
I'm thinking about buying some old IROC swaybars. I know the IROC has the hollow front bar and the matching rear bar.
I am sure the front bar will be a nice alternative to the solid bar that came on my car from the factory.
Is the IROC rear sway bar different than the one that came on my RS? I have heard that a lot of them were the same.
Who sells the urathane endlinks and bushings for those IROC swaybars?
Old Apr 21, 2002 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Not all IROCs were equipped with the hollow 36 mm front and solid 24 mm rear (my 85 IROC, for example had a solid 34 front with a 24 rear). GM makes higher durometer rubber bushings and poly end links. I can provide part numbers, if you're interested. As far as I know, only Guldstrand makes aftermarket 36 mm front bushings. Should you be interested in a set of 1LE/WS6 sway bars, please see me add in the classified.
JamesC
Old Apr 21, 2002 | 09:55 AM
xxwarrior36xx's Avatar
I got the aftermarket KNOI swaybars for my car. They only cost me 100 bucks and they are larger than my friends 84 Z28 sway bars. They came with polyurethane bushings and all. I was extrememly impressed by this. I do not know the exact size of them all I know is IT WORKS well.
Orr89RocZ
Apr 25, 2016 08:28 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
