HELP Brakes gone bad
Old Apr 23, 2002 | 02:23 AM
Beefy89's Avatar
Coming home from work last night my brakes started grabbing when I wasn't touching the pedal.I pulled into a gas station to check it ouit and I could barely stop,and the brakes were smoking like a train.....
The pedal is very hard and when pushed will hardly stop the car.
I don't know if it's the master cylinder or what..Any suggestions?
Thanks,Brian
Old Apr 27, 2002 | 07:20 AM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
Well, I just recently went through the same problem. I had replaced rotors and pads last Sept, so I knew they were not the problem. Yesterday I replaced the calipers (did both sides), still have the problem. Today I'll replace the brake lines on both sides. I'll let you know what happens tonight. While I have the car up in the air, I'll also replace the starter (again for the 4th time) - darn heat soak problem. Got a heat shield and absestos blanket to wrap the solinios and starter in.
Good luck with your brakes.
Well, finally got the brake hoses replaced, and man, what a difference. No more pulling or dragging brakes. WORKS GOOD AS NEW!!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
