aftermarket proportioning valves? a few ??'s
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
would an aftermarket PV solve my problem of weak rear brakes on my Bw 9 bolt? i am looking at other options besides removing spring from the stock PV, or would a 1LE PV. help (assuming the 1LE is diffrent) whatdayathink? man i need the rear brakes to work..
by the way if an aftermarket PV is the answer where do u get one?
thanks
by the way if an aftermarket PV is the answer where do u get one?thanks
Car: 89GTA
Axle/Gears: B/W3:27
poncho:summit has one..part#SUM-G3905 39.50$ from there latest catalog would this one work? i has one line going in and 2 out. Z28:all of my brake hardware is vintage89 BW disc brakes..
Hotrodboba400
Dec 10, 2019 07:07 PM
