replacing drum with disc brakes...opinions?
Old May 9, 2002 | 11:35 PM
mdr211's Avatar
Car: 86 camaro Z28
Engine: 305 carb
i'm thinking about taking some disc brakes from an iroc and putting them in place of the rear drum brakes on my z28. has anyone tried this before or if not does anyone know if it is a real problem. i don't want to have to change the brake lines but i think i might go ahead and do it anyways, though i've heard thats a real hassle.
Old May 10, 2002 | 12:16 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Welcome to the boards!!
Are you refering to swapping the axle or just the brakes? Depending how comfortable with tools and your car depends on your best route. Since it sounds like you are new to modifying your car I would suggest a complete axle swap. Depending on the gear ratio you have, it could also make the car a little more "peppy".
If you are certain you want to put disc brakes on your drum axle, check out this site: www.omega185.cz28.com
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
