Vibration/shaking from the rear
Old May 16, 2002 | 03:05 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
My Formula has developed what could be best described as a shaking at speeds around 60mph. It also seems to be coming from the rear end. I recently had a battle with vibration that was cured with a 1LE driveshaft. This is somehow different that the previous vibration deal though. I've been told that when these cars get high mileage(125K+) that the bearings start to wear grooves in the axles which allows unwanted play which can cause this. A friend also has this problem and swapped his poly bushing panhard bar for the OEM piece and the problem improved. Has anyone here dealt with this problem before and if so how did you fix it?
Old May 21, 2002 | 11:04 PM
Eightyninef's Avatar
get your tires balanced recently??
Old May 22, 2002 | 06:32 AM
Mongoose's Avatar
Car: 90 Formula
They were balanced during the vibration hassle.
Old May 22, 2002 | 08:45 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Have you hit anything recently? You could have a slightly bent axle.
Old May 22, 2002 | 04:29 PM
Mongoose's Avatar
Car: 90 Formula
Nothing that I'm aware of.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
