Relocation brackets?
Old May 17, 2002 | 11:54 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Where do they go? Anyone got any pictures or instructions? I lost mine.
Old May 17, 2002 | 02:46 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Relocation brackets go on the rear end. They slide over the brackets that the lower control arms bolt onto. You can get either weld on brackets or bolt ons, but the weld ons are the safest ones, since there isnt a chance of anything loosening up. The purpose of them is to make the rear connection point of your lower control arm LOWER than the front of it. It is reccomended to get these if you lower you car because when lowering, you screw up the geometry back there and the rear part of the LCA is HIGHER thatn the front part, making them much less effective. I believe I've seen some diagrams floating aroud somewhere that explains exactly why the rear of the LCA needs to be lower than the front, but I'm not exactly sure where they are.
From www.spohn.net
This product is a must for lowered vehicles to correct your suspension geometry. Lowering your vehicle alters the LCA angle putting the rear of the LCA higher than the front of the LCA, this causes massive wheel hop and traction loss.
NON-LOWERED vehicles will also see a dramatic increase in traction by lowering the rearward angle of the LCA with our relocation brackets. The lower mount holes are placed in the arc pattern of the OEM length LCA. Therefore allowing a non-lowered F-Body to drop the rear LCA angle and NOT require a longer than OEM LCA. All geometry is correctly maintained. The anti-squat performance is providing most users with a full .10 or better 60' reduction!
Old May 20, 2002 | 06:32 PM
Basett_Racing's Avatar
Here You Go!! --better than instructions
Old May 22, 2002 | 03:24 PM
tpi_roc's Avatar
Old May 24, 2002 | 05:18 PM
Scott_92RS's Avatar
Car: 1992 RS
Here's another good shot of one installed:
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
